Skydiver 6 foot new build.
That things big enough you could put two "McCullough chain saw engines in there, for surface propulsion!! -
Wow! Sweet stuff here! Reg Hill is smiling. You, sir, are a creative genius.
MLeave a comment:
MLeave a comment:
Back on this now as well, Added the grid vent tubes and If you look closley you will see I also defined the side venty things. Mark, I did the side vents by Laying down 10mm strips of Tamyia masking tape where the black areas would be, I then Plastered the area with Primer, Filler Primer and then Primer again. Removed the strips and Hey presto!.Leave a comment:
Good, please show me everything on how you cut the recesses and keep them looking straight. ThanksLeave a comment:
Ohhhhh Those..... Well the 5 footer ones were a bit of a mod I decided to do they were not strictly cannon. On this one I will create recessed lines/Depressions and Spray them gunmetal. These will be more in keeping with the original model.Leave a comment:
