Disney Nautilus
  • milanese
    • 7
    Disney Nautilus
    My new Disney Nautilus
    On the association's site
    Siamo un gruppo di amici amanti del modellismo in tutte le sue forme. Statico, Dinamico, Acqua, Cielo, Terra - Foto, Articoli, Mostre, Gare
    On You tube
    During the maiden voyge I had some problems, but it is under resolution now.
    Hi all
    Milanese
    Hello Alex
    http://www.amicidelnautilus.org
    Very nice indeed sir. Are the ballast tank and dry sections built by you?
    • milanese
      • 7
      Thank you
      Yes all WTC was built by me.
      Following the "masters" of this forum
      Hi
      Hello Alex
        • 1777
        Very nice! If you have room, I'd recommend some foam up top and ballast down low to try and counter that torque roll that you have. The 31" Nautilus models are pretty heavy so there's not much room for foam, but put as much as you can as high as you can with some ballast in the keel in order to keep it stable...
          • 2121
          You can also try a little less pitch on the prop, moving the torque curve higher up the RPM band.
          • milanese
            • 7
            Unfortunately, I know, but I've never built propeller........ I'll try (although I do not know where to start)
            The problem with foam/ballast is solved
            Thanks to all
            Hello Alex
              • 12318
              You start with a pair of pliers (sorry, Romel). That things white-metal, right? Twist away.
                • 2121
                Go with Bob's suggestion of adding foam and weight first, though.
                • milanese
                  • 7
                  No, it isn't in white metal.
                  the prop is brass (raboesch)
                  I've already reduced the diameter but it isn't sufficient.
                  Hello Alex
                    • 12318
                    Can you retro-fit the white metal propeller?
                      • 2121
                      Raboesch props are already quite low in pitch (roughly 1:1) so I wouldn't tweak that any more. Sounds like it's just too much top weight.
                      • milanese
                        • 7
                        No I can't.
                        I have to build a new propeller
                        Hello Alex
                          • 12318
                          Well, before all that, do as Andy said: more weight low, more foam high. That will increase the metacentric height of the beast, making it more stable about the roll and pitch axis.
                          I have spoken, so let it be written! (crack of thunder)
                            • 1777
                            If you're out of room inside (its a bit of a tight fit for some people), you could also try putting some clear plastic fins on the side of your rudder. Your video makes it look like the model lists to starboard under power. If you have a horizontal fin on each side of your rudder, have the port side one pointed downward and the starboard upward. In that way they may help to fight the twisting moment generated by the prop torque. The good news is that the action will also be proportional to the propeller thrust, as is your torque roll, so it may work well!
                            • milanese
                              • 7
                              Thanks to all for the advice.
                              Now I go to build :wink:
                              Hello Alex
