1/72 scale crew figures
  • Anuci
    Banned
    • 165
    Offered to whomever the lucky winner of this years build contest, a set of nine (9) action figures assembled and painted in 1/72 scale, if needed and wanted of course.
    Good luck!
    Al,
    If not claimed..... I would be interested Al.
      Wonder if I should continue the 1/72 figures -- initially worked up for the defunct 1/72 FOXTROT kit -- and press those into service as a generic 1/72 'figure set'?
ID:	68172Click image for larger version
ID:	68173Click image for larger version
ID:	68174Click image for larger version
ID:	68175Click image for larger version
ID:	68176Click image for larger version
ID:	68177Click image for larger version
ID:	68178Click image for larger version
        Skipjack crew!
          Skipjack crew!
          Sounds like a plan!
          • Anuci
            Banned
            • 165
            I believe their may be a demand for the figures if you can find the time to produce them, Dave. This with all the other work presently on your plate were my thoughts anyway. There appears to be a lot of kits on the market offered in 1:72 scale. They sort of spruce up the model when in display mode, IMO. The figures you make up are nice tho, as it appears there wouldn't be a need to painstakingly assemble the various body parts provided with many of the action figure sets usually offered, not a good thing if one's eyesight isn't all that good to start with, like mine. Unless that sort of thing gives the assembler enjoyment of course.
            Tom, the figures are yours, if not claimed.
            Al,
              Skipjack crew!
              how about an Adm. Rickover on the fairwater plane.
                Can't do that. Any crew member figure within a three-inch radius would either animate on the spot and run away screaming, or if it stood its ground, would spontaneously burst into flames!
                Besides, I can't build 'em that short!
                  A pair of wire cutters would make short work of them.
