Stingray Build
    HPC do internal gears. Not a cheap option, the gears are machine cut as opposed to moulded, so they cater to just about any size. You will need to machine the outer part to fit though.
  • RCnut
    Sanding drum mandrels. Neat!
    Thats them Yeh!!
  • RCnut
    Thanks David, Just a quick update, I have made a backplate up to replace the one seen in the vid. It now has built in Bearing housings for the rollers and I will mould and cast it for those that want to use it. The rollers are those Dremal rubber things that you put a sanding ring on (cant remember the name, lol). This is by no means the best way to do it being very low tech, An Internal ring gear and small pinion would be better but I'm having trouble finding one that fits. Pic tommorow.
    I'm most impressed with this project. And your desire to represent the model not only in form, but also in functions is most laudable. Love your work!
  • RCnut
    I am the slow one here......what does the spinning door knob do? Does it help stabilize the sub?
    Ok, The Ratemaster is "Supposed to" Dampen the torque effect of the Propulsor. But it was just made to spin in the show for effect. As I'm a bit of an anorak I like things to appear as they did on the effects model. That being said there were at least 4 Stingrays done in various scales and not all of them had spinning RMs on them.
  • RCnut
    Slick!
    Thanks David
    Slick!
  • RCnut
    As promised.
    GRRrrrrrrr!
  • RCnut
    Sorry David....Not going to do it that way, although that method was put forward by My Good lady and a few people. All will be revealed (If it works)
    Ah!... you sneaky so-and-so: your going to put some vanes on the inside of the RatMaster that will act as turbine blades to set the door-knob in motion when impinged on by the PJ flow. You're amazing, sir.
  • RCnut
    Ok as you can see Its a bit of a hodgpoge but it will serve its purpose, Its a bit further on than this and tomorrow I will see if I can make the ratemaster spin.
  • RCnut
    The point I was trying to get across is that for a boat with submerged propulsors you don't need the space hogging scoops used in waterjets. If you cut the front half off a waterjet you have a shrouded prop with some fixed pre-swirl stators. If you're running a boat on the surface with the impellors above the waterline, then clearly you have got to have scoops, else they will never get to see any water!
    Oh, lol..... I'm with you now, I totally misunderstood what you were refering to. In my head it was a normal prop in a shroud (Kortish).
