Skydiver 5 foot build
  • RCnut
    • Apr 2012
    • 441
    Hey Mark
    I know, but these jets are only for cruising around, I'm waiting for some 800KV brushless to come. If all goes well I will go for a sea skim function probably using the afore mentioned lower removable pod and/or hydroplanes. I'm so trying to think positively lol.
      Absolutely! Once you get her in the water and see how she does youll be able to see clearly where your at and what comes next. CHEERS!
      • RCnut
        • Apr 2012
        • 441
        I ordered the brushless motors today and the esc's so hopefully.........We shall see. lol.
        • RCnut
          • Apr 2012
          • 441
          Here we go
          Studio2models BIG Skydiver. First test to see if the water jets are working, Only running 8.4 volts at the moment, Motors capable of running 25 volts.
          I was quite pleased lol.
            • 2134
            Loved the dialog in the background!:biggrin:
            Should go even better with Sky 1 on the front. Perhaps steerable nozzles would improve the turning radius
            • RCnut
              • Apr 2012
              • 441
              Lol, that was My Mrs, Def will go better with Sky 1 on it, A friend of mine used a bow thruster on the front of his one. I'm sure steerable nozzles would turn it round much better but hiding them would be quite a task. Something to think about tho.
                • 2134
                How about a pair of spherical bearings on the nozzles, doubt if anyone will notice them, and even if they do, the don't look out of place. This place does plastic ones, or you could mould some.
                • RCnut
                  • Apr 2012
                  • 441
                  Blimey, you can tell I dont get out much lol, they look real cool. I will investigate further.
                    • 12370
                    Rick Teskey has a lot of practical experience with this type of thrust vectoring -- contact him.
                      Excellent video Mamas. What are the two green hoses out the side? Water cooling for the motors?
                      • RCnut
                        • Apr 2012
                        • 441
                        Indeed they are, I Just wacked everything in there for the test, now comes the good part lol.
                        • RCnut
                          • Apr 2012
                          • 441
                          Update, its all smooth now, Conning tower can now be fixed on and removed via a screw, Boxed off the vents etc. Time to start adding all the Greeblies.
                            Mamas, in the first picture,the longitudinal grooves on what I call the propullsion blister, about midway the length of the Diver section, how did you get yours to come out so perfectly.............perfect???
                            • RCnut
                              • Apr 2012
                              • 441
                              Hi Mark
                              Its just Plasticard sheets stuck together and sanded to shape. Thats the Master in the Pic.
                                • 12370
                                #30
                                This thread has my undivided attention. Wow!
