I need help with ADF2
  • beeryboats
    • Jun 2011
    • 124
    I have everything set up and calibrated on the ADF2. But as soon as I start to turn the drive motors the dive plane servo goes nuts. The failsafe side on the balast tank does not seem to be affected. Am I getting RF noise into the ADF? And how do I fix it?
    Thanks,
    Jay
    • 3758
    jay,
    I would offer the suggestion, since no one else is jumping in here, to PM KevinMc
    He is the creator of the ADF2 and a really smart guy.
    Tom
    • KevinMc
      • 305
      Hi Jay,
      Is this "dive plane servo goes nuts" situation you describe happening when you're on the bench, or in the water too? It's likely that the mechanical imbalances in your drivetrain are creating vibrations that the ADF2 is trying to counter-act. (That's the downfall of having a really fast controller!) If this is the case it's possible that your mounting tape is not providing enough mechanical isolation from your equipment tray. Before fretting about that though I'd try repeating the test with your cylinder floating in a bath-tub (sink, cooler, etc...) The additional damping of the water, and the fact that you're not bouncing on a hard table-top will likely cut the vibes to the point that the ADF2 won't be so bothered.
      Let me know if this helps!
      KMc Designs
      • beeryboats
        • Jun 2011
        • 124
        Success! I think. I relocated the ADF to the bottom, but that didn't help. Then I added three layers of foam servo tape and that seems to have knocked it down by 98%. It's still a little jumpy at neutral stick, but very little. It's rock solid otherwise. And it blows balast when I turn off the transmitter. Just awesome! And so easy to set up. It did scare me a little until I went by the instructions step by step.
          • 3758
          Yeah! Whoot!
          Time to get it wet?
          • beeryboats
            • Jun 2011
            • 124
            Still waiting for liquid water. It was 28deg this morning! It's that time of year, frozen or raining.
