Rubis class SNA Perle (S606)
If that doesn't pan out, these guys do some generic boards for resin printers. Unlike many filament printers, resin printers tend to be bit more bespoke when it comes to their control boards, but with the tech partially reaching a point of smaller incremental gain I think many are wishing to rebuild/refurb machines that are 'good enough' rather than partake in a constant upgrade cycle.
Adding rudder and horizontal control rods and stuffing box inside now for prop shaft. Rubber grommet in front inside brace on drive shaft.
I just sent Any Cubic support a query.
'Can I use successfully use a replacement motherboard for Photon Mono M7 Pro LCD 3D Printer Accessories S020228 compatible in a ANYCUBIC Resin 3D Printer, Photon M3 Max mother board S020107 ?'
Will see. Thank you for assistance.
I recived a reply for my question from Any Cubic support, if the mother boards are compatable. They are not.
Dear Customer,
Sorry for the late reply. Sorry the motherboards of Photon Mono M7 Pro and Photon M3 MAX are different, please do not replace them.
Best regards,
Suarez
Anycubic Support TeamComment
Okay, so it was worth a shot I guess. I would ask them why a replacement board is not listed for your model, after all it’s barely out of warranty. They may simply be experiencing component shortages. Might also be worth having a word with Chitu whose link I posted earlier. You printer does have a very large screen which makes it a little more difficult to source a compatible board. One of the reasons I like fdm printers is that they’re generally easy to source replacement parts for and you have a wider choice of you can use.
Resin printers tend to be a bit more bespoke.Comment
