Sheerline 1:27 German Type IID sub
    • 2642
    The Sheerline system works very well. These boats are popular in the UK and have been in production for about twenty years now, largely unchanged. We had several Sheerline boats merrily swimming about at the Summer Dive-in last weekend. Type II's are quite a rare sight, most people tend to choose the Akula or Trafalgar kits.
  • roedj
    • 564
    Yes, I thought I'd do something other than the generic black sewer pipe types.
    Dan
    • roedj
      • 564
      as received
      Let's start with some "as received" pix.
      Chris Cloke - Sheerline ships his kits in a custom made wooden box - very sturdy.
      ...Click image for larger version
Name:	001 wooden box as received.jpg
ID:	62697Click image for larger version
Name:	002b box with top off.jpg
ID:	62698Click image for larger version
Name:	002a box with top off.jpg
      This sturdiness was put through a "test cycle" by the gorillas at UPS as we'll see later on.
      Dan
      • roedj
        • 564
        more as received
        Opening up the box was easy as the top was not secured at all as a result of the UPS drop test cycle.
        Here's the lead duct taped to bottom of the box...Click image for larger version
Name:	004 sheet lead duct taped to box.jpg
ID:	62700Click image for larger version
Name:	005 lead for ballast.jpg
        Dan
        • roedj
          • 564
          separate internal box for fragile parts
          Chris builds in a separate internal box for small parts and uses lots of bubble wrap - very nice.
Name:	006 stuff in separate compartment.jpg
          Dan
          • roedj
            • 564
            Dan
            Just realized I may have given the wrong impression here. The fact that the top was not attached is in no way any reflection on Sheerline's packing method. There were plenty of staple and nail points in the top.
            The unattached top could have been the result of the UPS drop test or some inspection having taken place. I'm sure that the eyes of some Homeland Insecurity drone lit up when they X-rayed the box and saw the "bomb" with the metal tank inside. I just wish somebody had taken the time and effort to reattach the top. Sigh....
            Dan
            • roedj
              • 564
              yet more goodies from the box
              Here is the photo etch of the floor of the tower and the Kriegsmarine ensign.
Name:	008 tower floor mesh + ensign.jpg
              Here is the pre-assembled Kort nozzle assembly.
              ... Click image for larger version
Name:	009a KORT nozzle assy.jpg
ID:	62704Click image for larger version
Name:	009c KORT nozzle assy.jpg
ID:	62705Click image for larger version
Name:	009b KORT nozzle assy.jpg
              Here is the solid bow piece.
Name:	010a solid bow.jpg
ID:	62707Click image for larger version
Name:	010c solid bow.jpg
ID:	62708Click image for larger version
Name:	010b solid bow.jpg
ID:	62709Click image for larger version
Name:	010d solid bow.jpg
              Lots more to come.
              Dan
              • roedj
                • 564
                as received - on the bench
                I took the parts out of the box and "assembled" them on my bench. Here they are:
Name:	011a as received.jpg
ID:	62711Click image for larger version
Name:	011d as received.jpg
ID:	62712Click image for larger version
Name:	011c as received.jpg
ID:	62713Click image for larger version
Name:	011b as received.jpg
ID:	62714Click image for larger version
Name:	011e as received.jpg
                The inside of the top hull...Click image for larger version
Name:	011f as received.jpg
                The inside of the bottom hull showing the trench where the battery is placed...Click image for larger version
Name:	011h as received.jpg
                The pump end of the WTC ....Click image for larger version
Name:	012a pump end of WTC.jpg
                The motor end of the WTC ...Click image for larger version
Name:	012b motor end of WTC.jpg
                Dan
                • roedj
                  • 564
                  shipping damage
                  Results of the UPS drop test:
                  The collar around the WTC was cracked. I shipped the tank back to Sheerline. They will fix it - excellent service...Click image for larger version
Name:	013 damage to tank collar.jpg
                  During the UPS drop test a hidden flaw was revealed - it's sort of a good news - bad news thing:
                  There was a void in the layup between the gel coat and the glass mat which was revealed when the whole box got dropped on its nose. I shall fix this myself with either fiberglass paste (Bondo) or with some epoxy resin with Cab-O-Sil added to thicken the mixture. I'm actually glad this was found now rather when I augered into the side of a pool at warp3...Click image for larger version
Name:	014 damage to bow.jpg
                  Dan
                    • 2642
                    Looks like Chris didn't stick some rovings in the end. I would glass in a GRP or brass plate and build up around it with rovings and glass, sand back and then finish off with putty. Would stick with polyester resin personally, as that is what the hull is moulded in, but the epoxy will do the job.
                    • roedj
                      • 564
                      Will deal with the bow problem later. This is beginning to look more like a blessing in disguise.
                      Dan
                      • roedj
                        • 564
                        more stuff
                        Here is more parts from the box with a picture of the corresponding part on the Vesikko, a Type IIA, sub built by the Finns to German plans. Obviously, there were some changes made between a IIA and a IID but the Vesikko is the only type II sub left anyhwere in the world that I know of or have pictures of.
                        aft jump wire supports...Click image for larger version
Name:	023 aft jumpwire supports.jpg
                        anchor + housing...Click image for larger version
Name:	023 anchor + housing Vesikko.jpg
ID:	62723Click image for larger version
Name:	023 anchor + housing.jpg
                        ballast tank cradles...Click image for larger version
Name:	023 ballast tank cradles.jpg
                        bow dive planes...Click image for larger version
Name:	023 bow dive planes Vesikko.jpg
ID:	62726Click image for larger version
Name:	023 bow dive planes.jpg
                        Dan
                        • roedj
                          • 564
                          more more stuff
                          Carrying on...
                          bow hull locating pins,,,Click image for larger version
Name:	023 bow hull locating pins.jpg
                          jump wire junction plate...Click image for larger version
Name:	023 jumpwire junction plate Vesikko.jpg
ID:	62729Click image for larger version
Name:	023 jumpwire junction plate.jpg
                          schnorkel - the Vesikko had no schnorkel. Only a few Type IID's did. I'll probably end up painting it like U141...Click image for larger version
Name:	U141 colors.jpg
ID:	62731 which did not have one. I may add it anyway for the "cool" effect. I never said I was a rivet counter. Here is the schnorkel...Click image for larger version
Name:	023 parts schnorkel.jpg
                          Dan
                          • roedj
                            • 564
                            more more .....
                            periscope base...Click image for larger version
Name:	023 periscope base Vesikko.jpg
ID:	62733Click image for larger version
Name:	023 periscope base.jpg
                            prop shaft support...Click image for larger version
Name:	023 prop shaft support Vesikko.jpg
ID:	62735Click image for larger version
Name:	023 prop shaft support.jpg
                            torpedo hatches...Click image for larger version
Name:	023 torpedo hatches Vesikko.jpg
ID:	62737Click image for larger version
Name:	023 torpedo hatches.jpg
                            tower hatch...Click image for larger version
Name:	023 tower hatch.jpg
                            Velcro straps for WTC...Click image for larger version
Name:	023 Velcro straps.jpg
                            Dan
                            • oztruck
                              • May 2010
                              • 317
                              Looking forward to this build. You are off to a good start.
