German type XVIIb
    Manfred, if you want, send me the dimension and photo of your gyro part, maybe I can 3d print a holder. Rcdotsubmarineatgmaildotcom
      • 1662
      #107
      Tom, thanks for the offer, if i don't succeed in modifing the old bracket, you will get a call, there are certain features present on the old bracket that i need for adjusting the gyro, we will see how it goes
        • 1662
        #108
        Allmost there, compressorpack is placed, runned some tests with the 12V mainpack and compressorpack, removed some lead from inside the ballasttank.
        Since the mainpack of 12 V is in running order i could find out which valve went where, on this boat i run three valves, 1 main valve for flooding the tank, 1 valve from trimming the boat and 1 valve for raising the boat.
        Testing if this would work, i need the room between the batteries for the pendulum of my gyro.
        Glued in place with the wooden piece between them, this had to cure 24 hrs before i could remove the wooden piece.
        This amount of lead was removed from the ballasttank, it's about 775 gram, this should give me some more freeboard, which i can test out next spring in the testpool.
        Builded back the floors on the batteries which alloud me to place back the valves,and a view of the remaining lead inside the ballasttank, checked if everything is still solid glued down, the lid on top of the tank will be fastened back with a seal between the tank and the lid, when done i can do some pressuretests if the tank is fully watertight.
        Once this is done i can alter the bracket of my gyro, it has to be removable for maintenance.
        Just like David has, i got me my grubby hands on a X craft scale 1:35, this will be the next project next year.
        To make things worse i also ordered the Eduard PE set for this boat, gotta love details.
        A 2" SD is clearly too big for this boat, i need to get my hands on a 1.25" SD or build this as a dryhull, just as my Bibers and Seehund, have to see about that in the future, for now first finish the maintenance on the XVIIb.
