New Galathée Sub - ADX Models (France)
  • solosub
    • 51
    Hello Guys, and sorry for my English :oops:
    It's always an emotional moment, opening a big box containing a model kit of submarine RC :)
    But this time the symbolic dimension is there because it is the first model sold by Aurélien DOUX since the end of the company Lecma!
    We were fortunate to discover a few days ago the range of our 2011 National craftsman and now includes a model as iconic as the Galatée;)
    New topic devoted to assembly of the first submarine ADX Galatée, "a first then, is only ScaleSub!
    The purpose of this subject is also to demonstrate that the Galatée is a model that can be mounted on a corner office with minimal equipment and in a relatively short time.
    We'll see, by spending 1 hour a day to assemble the submarine, how long it will take to finish it :D
    The contents of the box is always full, in fact, pump, motor, battery, cables and other linkages are present. The manual is detailed and makes assembly step of the model, note in passing that it is now stamped with the logo ADX Models :)
    Well it was too tempting, so tonight I set up the main rack. Children's play and above all a pleasure to assemble, it must be said that the ultra fine cutting CNC provides exceptional precision.
    Parts are detached from the main plate, they are deburred and sanded.
    One hour for this first part, cutting parts, tightening the screws :mrgreen:
    See you :P
    Laurent
    www.scalesub.com
    French RC submarine forum
  • solosub
    • 51
    Hi,
    1 day/1 hour, here after making the Galatea from 2 hours devoted to assembly of the submarine;)
    Begin the back by cutting and sanding the PVC cones.
    Then it prepares the cap back on fixing the stern tube and thru-hulls.
    The cone is now set to end cap to form the rear of the model.
    Laurent
    www.scalesub.com
    • oztruck
      • May 2010
      • 317
      Can't wait till tomorrow. looking good.
      • Rpmtech1
        • Dec 2009
        • 229
        I always admired this model, especially when I first discovered it via one for sale, complete with all working lights.
        Very nice sub!!
        • Slats
          • 1776
          Its a great looking sub Laurent, do you know if you can buy this as a kit without the internal water tight cylinder?
          John
          sigpic
          • solosub
            • 51
            Hello John
            No, it's impossible to buy the kit without the WTC because the submarine is built around the WTC.
            Regards
            Laurent
            www.scalesub.com
            • solosub
              • 51
              Hello,
              Here is the result of the third hour devoted to Galatea 2
              The work today is on the tail cone and liaison with the rack.
              Laurent
              www.scalesub.com
                • 13982
                Outstanding photography and solid step-by-step presentation. Keep it up.
                God! What an ugly boat. But, it's growing on me. Keep posting!
                • solosub
                  • 51
                  Hi David,
                  Sure it's not a pretty hull :biggrin:.
                  But it is a small model easy to carry and perfect for putting a small camera.
                  Laurent
                  www.scalesub.com
                  • Rpmtech1
                    • Dec 2009
                    • 229
                    I think it looks cool, in an robot-machine sorty way like all research subs. But yes not "pretty"
                    This thing needs some mean, working manip arms.
                    • solosub
                      • 51
                      Hi !
                      Already 4 hours of construction :D
                      The assembly step by step of Galathée pressure ballast .
                      Soon, it will be time to address the electronic model :P
                      Laurent
                      www.scalesub.com
                        • 651
                        Laurent
                        Are you working too hard, where is the next part.
                        • solosub
                          • 51
                          Hello :)
                          It's been long since I have not worked on the Galatea, but after 2 hours of construction, the electronics are mounted in the submarine.
                          Laurent
                          www.scalesub.com
                          • Rpmtech1
                            • Dec 2009
                            • 229
                            What a clever ballast pump switch/valve! I love it.
                            • solosub
                              • 51
                              Hi,
                              After 2 hours and fews pictures
ID:	62227Click image for larger version
ID:	62228Click image for larger version
ID:	62229Click image for larger version
                              Next step testing in the pool :wink:
                              Laurent
                              www.scalesub.com
