1/72 Victor III molds
  • 598602G
    • Jan 2017
    • 518
    #61
    I just got a 1/72 688 LA class SSN kit from Bob. Anyone build one of those kits yet?
      • 13998
      #62
      Whoh!, whoh ….. whoh!, there Tom. Didn't I sneak into your room the other day and cut out your kidnys? Oh! …… wait. I'm mistaken, that was someone else.
      Never mind
      Tim: You get on the FOXTROT project and I'll assist any way I can. Let's make that beauty happen! We already have a massive head-start:
      • 598602G
        • Jan 2017
        • 518
        #63
        OK Dave the Foxtrot is on. I am making the Victor sails today. Wish I had a way to 3D print those sails as they are a pain in the rectal cavity to make. You got anything for my 1/72 688. Those 688's just came out when I was on boats. Have to go get some shipping boxes for Bob's stuff and your Victor. Soon as I get back I will get a hold of my Russian comrade and order the Foxtrot plans.
        • 598602G
          • Jan 2017
          • 518
          #64
          Guess I better not change my name to Rick Palumbo.
            • 13998
            #65
            For God's sake, Tim! Don't give in to the Dark Side! You got two hands and a brain …… use 'em!
            I've only done a comprehensive mast array for the 1/72 THRESHER/PERMIT kit. Nothing for American boats after that class in that scale. Sorry. Here's what I do have -- let me know what you need and I'll cast them up for you, Tim:
            • 598602G
              • Jan 2017
              • 518
              #66
              Dave whatever Thresher masts/parts you think the 688 could use yeah I will take whatever I can get. The 688 kit is real nice. Made in the Czech Republic. I thought I made thick hulls. Put my calipers on the 688 hull and it is .145'. Uses like a pvc sewer pipe for the main hull. Might have to show the build on that. Dave how about you make the sail molds and maybe the appendage molds and I will do the hull. Need to find some pics or drawings that show the hull plating lines because I will mold those in the hull.
              • 598602G
                • Jan 2017
                • 518
                #67
                Dave your Victor kit should be ready by Wednesday. Going to ship Bob's Victor tomorrow.
                  • 13998
                  #68
                  (joyous squeal of joy like a little girl) Thank you, sir. I'll put it into the rotation. Just as soon as I work out the topside displacement I'll prepare your SD and get it off to you.
                  • 598602G
                    • Jan 2017
                    • 518
                    #69
                    Cool. I was just checking out the 688 kit. Man that center hull is heavy. It feels like it weighs about 5lbs. Is that going to be OK for a RC sub or am I just going to have to make a epoxy glass hull? That thing gets a direct hit from a depth charge and it won't dent it.
                    • 598602G
                      • Jan 2017
                      • 518
                      #70
                      Pic of the 688 hull. .145" thick.
                        • 3767
                        #71
                        Woof, that is beefy!
                          • 13998
                          #72
                          Well, you're in luck. Modern American single-hull submarines have a ridiculously low reserve buoyancy of about 15% (the later flights of LA's anyway). So the freeboard of your 1/72 LA models hull is about .75". Work the math for volume of water displaced by the above waterline portions of that hull, add to that the displacement of the sail and upper rudder, then crank in 15% because we're dumb-asses, and you get the volume of water we need to move in and out of the ballast tank.
                          God damn, that's thick!
                          • 598602G
                            • Jan 2017
                            • 518
                            #73
                            That hull could almost stop a AK-47 round. I bet those Czechs used schedule 80 pipe instead of schedule 40. Have to go nose around Lowe's and see if I can find a schedule 40 pipe that is exactly 5 1/2" in diameter. Not much in the way of instructions on how to build it but I have it figured out. I will show the build on here. Thanks god I have one of your 7 bladed 65mm props I can use for it.
