. Bill Bibeault Bronco Type XXIII Build
  • cgbillb
    • May 2018
    • 182
    #76
    Up date on my U-2326 build. I did sanding yesterday on the Kerf and started to install the tabs, will finish today
    Only a couple of photo , as David piece on Making up the Kerf tells all with great photo's
    Bill.
    • cgbillb
      • May 2018
      • 182
      #77
      Here is David's build
      • cgbillb
        • May 2018
        • 182
        #78
        OK a few photos of the taps
ID:	128207Click image for larger version
ID:	128208Click image for larger version
        Guess you cant see the U-2326 I made on the 3d printer will do better next time
          • 13941
          #79
          Originally posted by cgbillb
          Yes the two add on for the U-2326 will be lights and a camera, I look at yours and Amazon does not have them..
          I google underwater cameras came up with the one I show you. My Attack Group of builders have waterproof camera on them.
          They get them from Amazon for $29, will see if I can find a photo later.
          I will watch the YouTube a little later at my work out.
          Bill
          Look for, '808 video camera'. You want one with the wide-angle lens. And make sure it shoots in HD.
          • cgbillb
            • May 2018
            • 182
            #80
            ok thanks will go look for it
            • cgbillb
              • May 2018
              • 182
              #81
              David can I get this from you?
              Love it
                • 13941
                #82
                Love it
                That WTC will only accept the Swann type camera-transmitter. Can you find one? If so, I'll fix you up.
                Back to work!
                  • 13941
                  #83
                  • cgbillb
                    • May 2018
                    • 182
                    #84
                    OK David thanks I will check in to it more as time goes on
                      • 2617
                      #85
                      What's the diameter of that camera pod, Dave. I think there may be a small action cam out there that will fit in that.
                        • 13941
                        #86
                        Just found this unit on evil-bay. Snatch it up before it's gone. Hell... … get two of these things!
                        https://www.ebay.com/itm/Swann-Wirel...UAAOSwElxbyNqw
                          • 3732
                          #87
                          Resolution did not look great on the $15 unit ($17 shipping).
                          Bill, do you just want to record what is going on for later viewing or live viewing?
                          My first thought is stop looking at distractions and get this sub built (wow, I sound like David)! You can retro fit stuff later on. I have recorded on board and off the sub. The water has to be CLEAR or you record a green screen of cloudy water.
                          Here is one of a skipjack (and this pond is pretty clear):
                          • cgbillb
                            • May 2018
                            • 182
                            #88
                            Tom (David Jr.)
                            Yes your right , will look into it more later.
                            Thanks for information
                            Bill
                              • 13941
                              #89
                              https://www.gearbest.com/action-came...SABEgLlkfD_BwE
                              1.124" inside diameter, Andy.
                              • cgbillb
                                • May 2018
                                • 182
                                #90
                                Tom
                                Did you try to connect spot lights, see if it would help the
                                Resolution
                                of the camera at all?
                                Bill
