Moebius Skipjack
  • Ken_NJ
    SD foundations are in. For the forward foundation I cut the service slots for the shock absorber before I glued the foundations in place, made things easier. I read thru Tom's build and saw he had an issue with the strap foundation with the bolt hole being over a vent. I thought I had it covered, but I didn't, duh. I'll be moving the bolt hole back a little and then open up that vent, just like he did. Besides, the bolt hole in that spot was stripped in the foundation, so a new hole would have been needed anyway.
    How and why did I miss this, ugh!!!
    That shelf is a great idea, it serves to keep things neat and holds the battery from shifting. Excellent!
  • Ken_NJ
    From my previous question I should have plenty of room in front of the SD for anything. Found my own answer.
    I wanted a good place to mount the key-fob unit. Since there was plenty of room in the forward chamber I built a tray to mount the device. I like the outcome.
    More details here... https://kensmodelboats.com/uss-skipjack/
  • Ken_NJ
    Getting close to finishing up setting up the SD. Question for you SJ guys. I’m not close to assembling the hulls yet so I don’t know about clearances yet. Is there enough room at the outside front bulkhead to plug in a waterproof cable and hose for the Depth Cruiser? Those are attached to the upper hull so I suspect I’ll have to plug those in while holding the upper hull, then attach the upper hull to the lower. The DC hose inlet will be the same as the vent tubes on the aft bulkhead.
    If someone was going to install a torpedo assembly I suspect there should be plenty of room from the forward bulkhead to the very bow. I will not be installing torpedoes.
  • Ken_NJ
    On advice from Kevin McLeod I bought this on Amazon... https://www.amazon.com/Hitec-Inc-Ser.../dp/B08233NLW1
    Installed it between the receiver and BLM on channel 4, now all channels work like they should.
    Click image for larger version  Name:	IMG_2666.jpg Views:	0 Size:	84.9 KB ID:	147028
    Click image for larger version  Name:	Skipjack diagram.jpg Views:	0 Size:	83.0 KB ID:	147029
  • Ken_NJ
    Gotcha Tom. Like this... https://www.amazon.com/Hitec-Inc-Ser.../dp/B08233NLW1
    Found this on Hobbyking, nice and small instead of the long y-cables.
    https://hobbyking.com/en_us/servo-sp...emale-6cm.html
    New diagram/layout....
    Click image for larger version  Name:	Skipjack diagram.jpg Views:	0 Size:	83.6 KB ID:	146954
    Sorry Ken, Y-cable.
  • Ken_NJ
    Tom, whats a standard splitter?
    Going back and forth with Kevin of KMc. He said the receiver might not have enough signal power for the BLM. He mentioned sending me a amplified device to go between the receiver and BLM. Still working on that. Alll to do with the board version of the BLM I have. First generation.
    The custom splitter may not be helping you. If I used a standard splitter, I had issues with the signal getting lost, so I changed to a y cable with a booster in it. I may not be using the correct terminology for it. For me, that corrected the issue I was having. I do not know if it is the same for you.
  • Ken_NJ
    I'm using the Hitec tramsitter for both the Marlin and the SJ. I have a VEX receiver in the Marlin. Using a Futaba receiver in the SJ. All on CH77. On this Hitec Ch5 is a toggle, using for the torpedo doors. Ch6 is a knob. You are right, I should have the stern planes on Ch6, like in the Marlin. I'll change that. BUT, using this Futaba revceiver I cannot get Ch5&6 to work. Something funky in the circuitry??
    I do have an Airtronics transmitter/receiver on CH64 that I am not using. This one only has toggles for Ch5 & Ch6
    I have an email out to Kevin as well to see if he can shed light on my problem.
    Are you currently using the VEX transmitter, Ken?
    The ch-4 routing looks good now.
    Why are you working the sail planes and stern planes in parallel? It will work, but only within a rather tight speed-depth window. Pitch control gets funky out of that window. Recommend you put the stern planes on the 'flap' knob (ch-6), ch-2 for the sail planes. Most of your depth control will be with the sail planes. Most of the time you will be hands-off of the knob controlling the stern planes (like a big trim wheel); only use the stern planes for radical depth changes (such as going emergency deep when some ass-hole comes barreling in on you).
  • Ken_NJ
    I only had the battery setup done, did not do the failsafe. Will try both again.
    Tried swapping crystals between transmitters, did not work well. Have to find another crystal to match the other transmitter.
    New diagram...
    Click image for larger version  Name:	Skipjack diagram y.jpg Views:	0 Size:	40.6 KB ID:	146941
    Originally posted by Ken_NJ
    Corrected that. The CH5 servo is still not responding. If I unplug the BLM then the servo works. Still have a problem.
    You're going to hate me for this, but... go through the BLM set-up tasks again and see what you get.
    Have you tried a different transmitter, Ken?
  • Ken_NJ
    Move your splitter/Y-connector from the receiver and to the output side of the BLM. The BLM outputs then goes to the LPB and ballast sub-system servo. The ch-4 port of the receiver services only the input side of the BLM.
