My official 1/72 german type xxiii build thread
  • matthewnimmo
    • Dec 2011
    • 271
    i have made my choice as some of you read in my previous thread deciding between 1/35 version or the 1/72. Due to size and over cost ive chosen the smaller scale. This build will take time as i have to save up funds for each part. In about 4 months ill be purchasing the custom static diving unit 1.25" from sub-driver. But below is my alanger model that just came in the mail!
    Alright then Mathew, then let the "Games" begin
    • matthewnimmo
      • Dec 2011
      • 271
      So, I received my wfly 8 channel receiver this week and i have my model. The month of April ill be putting back 100 bucks to save up for my SD. While i wait i guess i could start some work on the model. The inside of this thing is pretty much empty. So a couple questions
      1). Is it best to start working out the linkages now before i glue the two halves together? Im assuming even with this small scale i glue the model together and cut the top off like we normally would see in the Bronco build?
      2). Any thoughts or better suggestions on where to start while i wait for my SD?
        • 3754
        I, and others, have builds post here. Check those out.. You have plenty you can do before getting the SD.
        Tom
        • matthewnimmo
          • Dec 2011
          • 271
          Tom
          Cool! Same model and scale? Ill do some digging
            • 3754
            Although ours are for the larger version, I can imagine they are very similar in core build.
              • 13980
              Just as you described: glue that sucker together then cut it in half equatorially. Wait till the SD gets there to work out the running gear and linkages.
                • 13980
                I've started in on the two SD's for the 1/72 Type-23. Tonight I'll glue the two halves together and later in the week cut the hull equatorally. Follow along at home, Matthew.
                A little bit of scale for you:
                A rough of the wiring involved and the devices:
                The SD will eventually look something like this:
                  • 13980
                  • matthewnimmo
                    • Dec 2011
                    • 271
                    Hey David. Thanks for posting this up! I plan on glueing this guy together soon and stage my cut
