Trumpeter VIIc 1:48 (static)
  • DrSchmidt
    • Apr 2014
    • 1343
    #91
    What about "I don't care" hasn't been clear?
    • bianco64squalo
      • Apr 2017
      • 94
      #92
      Ok, no more words....
      • DrSchmidt
        • Apr 2014
        • 1343
        #93
        Again small progress. I decided to add the actuator for the rear dive planes. You can see it in front of the stern torpedo tube. It's basically an electric motor with a gear box and a push rod driven by a thread road. The thing is pretty much the same thing than the one driving the rudders. Modeled in CAD, 3D printed, painted......
          • 13728
          #94
          For what it's worth ...
          I've been following your work here. Wow! Simply amazing, sir.
          • DrSchmidt
            • Apr 2014
            • 1343
            #95
            Progress is still slow. I attached the photo-etched parts for the stern limber holes. That was a first for me and took a while, especaially because I removed the hull sections so that the remaining parts resemble steel ribs. One can look inside this section, so it has to look good. Also scratch built and installed the lower bulkheads behind the end of the pressure hull. Also scratch built the stringers between the pressure hul and the bulkhead of the rear dive bunker. Pain in the ass, but I'm pleased with the result.
            • The Boattrainman
              • Mar 2016
              • 443
              #96
              Hi Dr S.
              I'm wondering about the etched brass piece for the flood drain holes at the aft section around the props (2nd photo above). It's the one area I'm seriously worried about on my 1/40 sub, it's very complex, and there's no solution other than directly drilling the hull which I doubt I could do accurately. Is that an aftermarket piece or did it come with the kit? I've tried contacting a guy called Boris Naprokin on the web, who does lots of brass upgrade stuff,but to no avail.
              Any suggestions?
              • DrSchmidt
                • Apr 2014
                • 1343
                #97
                Hi, I use this detail set.....it didn't come with the set.
                • The Boattrainman
                  • Mar 2016
                  • 443
                  #98
                  Thanks, super site, a wealth of stuff there!
                  • DrSchmidt
                    • Apr 2014
                    • 1343
                    #99
                    Yes, and the guy is friendly as well. Bad English though ;-)
                    Glad I could help.
                    Cheers Andreas
                    • The Boattrainman
                      • Mar 2016
                      • 443
                      #100
                      Hi Andreas,
                      The scale is a bit small for me, however your post got me motivated to contact Boris again, turns out I was e-mailing the wrong address.
                      He's making me scale front and rear lower flood/drain holes to the pattern you are using but in 1/40 scale. Phew!
                      Thanks for the help again.
                      • DrSchmidt
                        • Apr 2014
                        • 1343
                        #101
                        Filling, sanding, filling, first kiss of primer....nt fully there yet but it starts looking like something.
                        • DrSchmidt
                          • Apr 2014
                          • 1343
                          #102
                          A first impression with the lights on.....
                          • DrSchmidt
                            • Apr 2014
                            • 1343
                            #103
                            Still slow progress. Had a lot other issues and so the work on the boat paused for a while. I started cutting the deck of the hull so that the photoetched deck will look real. I also started to paint and waether the outer section of the aft torpedo room....starts to look like something.
                              • 1994
                              #104
                              This is utterly breathtaking work. Thank you so much for sharing your progress and information!
                              • DrSchmidt
                                • Apr 2014
                                • 1343
                                #105
                                Thanks! I try my very best...
