USS Nautilus - Final Edition
    • 1393
    After successful test runs with the prototype, I've decided to incorporate my experiences with it in a second, improve version of the Nautilus. This time it will reach its design waterline and will have a higher battery capacity. I start with a complete set of parts that would also make a kit (in case I do it):
    GRPparts: All parts made by glass cloth with epoxy gelcoat as top coat. Moulds were fabricated based on CNC-milled masters. The parts comprise:
    - Bow
    - Main hull
    - Stern
    - Service hatch
    - Sail
    - all control planes
    - rear bulkhead (not depicted)
    PVC milled parts: All parts for the inner structure, additional pats and the standCNC milled out of 5 mm and 2 mm PVC:
    Brass parts: Photo-etched decks and accessories. 2 x scale brass props custom-made by the PropShop (UK)
    Resin parts: Accessories and structure components made from PU resin:
    A set of decals with ships number, name, draft marks...
    Bought parts:
    Engel Modellbau:
    1 x Hall sensor for Compact-Tank Controller CTS2 (1585-H05S)
    2 x Compression Fittings 2 mm (3289)
    1 x Compact-Tank Controller CTS2 12V (1584-CTS2-12)
    1 x Piston Tank EA 12V 540 -custom made- 1000 ml (1588-EA-12)
    1 x Autoleveler SPC2 (1574)
    1 x Pressure Switch 3,0 mm (5029)
    2 x ROXXY® BL-Outr. C35-29 500kv 4989 (RO4989)
    Hobby-Lobby Modellbau:
    10 x Rail posts 11 mm , 3 Durchzüge (910-11)
    2 x Standard Wellenanlage , 170 / 125 mm M4 (5000-05)
    Conrad:
    2 x Roxxy Bruschless-Control 930
    Hacker:
    1 x TopFuel LiFe 30C 4100mAh 4S (44100451)
    Graupner:
    2 x Graupner Servo digital DES 47 (7917)
    Brüggen:
    1 x Bayonet Catch 99 mm x 88 mm
    1 x Receiver Corona RP8D1
    And small stuff like bras tubes, rods, connectors.....
    • 1393
    We start with the bow section. Limber holes, deck openings and the holes fort he bow planes have to be defined. The bow planes will be fixed which proved sufficient on the prototype. The bow planes are tilted upwards 30° with respect tot he horizontal. That was not the original state, but during the test runs oft he Nautilus vibrations occurred at the bow planes that disappeared when the planes were tilted 30° upwards. So this was adopted. I work forward along my self-made manual:
    Clean the seam with 400-grade sandpaper and flatten the base plane:
    Same with the PU resin bow plane mount:
    The mount is further hollowed out to reduce its volume above the waterline:
      • 1393
      Mark the deck openings, roughly cut them with the diamond wheel and the file it to end dimensions:
      I decided to make the limber holes on the lower side closer tot he original (in contrast to the 12 mm hole depicted in the manual). For marking I made a styrene stencil. Drill the holes out with a 1 mm drill and file them to their final shape using a diamond file.
      Mark the position oft he bow plane shaft. Here precision is mandatory as precisely positioned shafts make the assembly oft he mount absolutely easy. If everything fits, it’s just a snap together job. Note that the mount was adjusted to the inner contour oft he hull near the seam:
        • 1393
        Mark the position fort he slits fort he bow plane mechanics, drill and file:
        In the region oft he slits I have removed more material from the mount:
        Mark the limber holes with a styrene stencil, drill and file:
          • 1393
          Same fort he anchor housing:
          Cut the anchor housing according tot he manual -> les volume above the waterline:
          Drill vents and the hole for mounting the anchor:
          Fit the anchor housing in the bow section:
          Glue 1,5 mm diameter brass rods into the anchor housing:
          Fix the anchor housing and the bow plane mount with superglue and then use long curing epoxy to make everything rock solid:
            Excellent work sir! You have my complete attention. So, on this improved version, Are the limber holes and other details going to be cut in already or just marked so that the end user does his own?
              • 1393
              Improved mostly with respect to a bigger piston tank and higher battery capacity. The boat will have a dry hull and the limber holes one has to cut are basically only the ones you see above. That's a day's job. So no markings.....
                • 1393
                The anchor housing has ben glued into the bow with is edge protruding about 0,2 mm above the hull surface. Against this edge one can now easily fill the remaining gaps using polyester putty. After everything is cured, everything is just ground flat using 400-grade sandpaper and wet sanding.
                With that the bow section actually would be done. But I have decided to put all those limber holes on the floor oft he bow. This is exactly the place where later lead hast o be positioned for the trimming oft he boat. To prevent blocking of the holes by the lead, I’ve decided to incorporate an intermediate deck. The deck is fabricated from 0,75 thick styrene sheet material and a styrene strip. After fitting the deck into the inner contour oft he bow, it was glued into place using epoxy.
                  • 1393
                  Everything is cured and ground. The bow section is done for now:
                  Next is the pressure tight section oft he main hull. Again everything is done according to the manual:
                  First the base planes and seams are again flattened using 400-grade sandpaper:
                  Then the installation oft he bayonet catch. First the wall thickness oft he main hull ha to be reduced in the area the outer ring oft he catch has to fit. Fort hat one first marks the depth oft he outer ring:
                  Bubble wrap protects the hull. Then it gets dirty. The wall thickness is reduced using a hand drill and a milling tool. It’s important to take enough time and to work carefully. The bayonet catch is the biggest opening in the hull and therefore has to be fit with maximum precision. In addition, ear protection and dust mask are mandatory for this step. All in all it took me about an hour to complete the milling.
                  While milling down the wall thickness, occasionally test the fit oft he ring. It hast o slide into the opening without the use of much force. Additionally I recommend to test fit the bayonet catch inside and outside the hull. There mustn’t be a difference. Otherwise the outer ring sits too tightly in the hull and thereby gets deformed. Clean the milled out section with 180-grade sandpaper and break the edge (so that the ring slides completely into the opening). Then glue the ring into place using slow curing high strength epoxy.
                  Epoxy residues on the hull and in the ring should be immediately cleaned using acetone and a cloth or Q–tip, respectively.
                    • 1393
                    On it goes with the counterpart oft he bayonet catch in the stern section:
                    Again the GRP is thinned down until the inner ring fits precisely into it:
                    The PVC deck support is adjusted and fit in:
                    Then the bayonet catch is positioned – put together and mark the position. Turn the inner ring until the catch can again be released – second marking. The middle bewteen these to marks is the locked position of the catch. Fix the inner ring in this position with adhesive tape.
                    Put the stern section on the inner ring, adjust its position, and fix it with epoxy.
                    The deck support is glued into position:
                      • 1393
                      When everything I cured, fill the remaining gaps between inner ring, stern section and deck support with thickened resin or epoxy:
                      On the main hull, glue the resin adapter into position:
                      The bearings for the stern plane axles are cut out of 4 mm x 3 mm brass tubing (4 pieces, 5 mm length each):
                      The bearings are glued into their seats using epoxy. Remove excess epoxy using a clot and acetone. Check the bearings with a 3 mm brass axle. Because of the CNC–based fabrication of the GRP parts, the position of the bearings should be on spot without the need for adjustment:
                        • 1393
                        Installation oft he stern tubes is quite simple:
                        I use standard stern tubes, 170 / 125 mm M4 mit 6mm outer diameter from Hobby-Lobby-Modellbau.
                        The surface of the tubes are sanded with 180-grade sandpaper and then put into the tube tunnels in the stern section. They should slide easily into the tunnels. If not – more sanding. The inner edge of the service hatch rim is trimmed so that the set collars have enough space.
                        The stern tubes are pushed far enough into the tunnels so that the hex nut of the of the propeller axle are hidden in the stern wings:
                        When everything fits, the tubes are fixed using superglue and then reinforced using epoxy:
                          • 1393
                          Fitting oft he service hatch. Again lots of grinding using a Dremel and 180-grade sandpaper. When the hatch is mounted, the remaining seam must be minimal.
                          Then, the deck opening in the stern section is marked and cut using a diamond wheel and file.
                          The opening can now be used to check and optimize the glued interface of the bayonet ring.
                          Next is the inner structure, which is made of two parts. The first section which is mounted on the rear bulkhead and the following mains section.
                          One starts with the first section. On the snap together components, the round milled contours of the PVC parts are filed to 90° angels.
                          The holes in the GRP rear bulkhead are opened and the section of that will be glued together are sanded with 180-grade sandpaper.
                            • 1393
                            The servo board and its support are glued together using PVC glue:
                            The holes for the servo fixtures are countersunk:
                            The cured servo board is glued to the next bulkhead in a 90° angle using again PVC glue.
                            With the brass tubes for the thread rod and the water supply the whole assembly can preliminary be put together.
                            M4 stainless steel thread roads are cut to length:
                            The thread roads are thoroughly cleaned and the corresponding stainless hex nuts are cleaned and sanded. Then the thread roads are glued watertight into the rear bulkhead using epoxy. The whole assembly is still just preliminary put together.
                              • 1393
                              After the thread rods are fixed in the rear bulkhead, the whole segment can be glued (epoxy) and screwed together. The position of the hex nuts can be used to fine-tune the position of the PVC structure:
                              Also the service hatch needs some limber holes for the flooding of the stern section. Mark the centerline: Mark the contour and centerline on a board. Then transfer the position of the centerline using a right angel:
                              The limber holes are marked using the stencil fabricated for the bow section:
                              Then drill and file:
