Revell Gato working doors
  • RonP-UK
    • Feb 2010
    • 67
    Mike Caswell has asked me to help out by posting some pics of my working Gato doors so you guys can have a go, I've posted it here as I guess its a gizmo and, what the hell, I might win a chocolate teapot.
ID:	99849Click image for larger version
    I cut the doors out carefully using a razor saw and scalpel blade to keep the cut as thin as possible, but to make up the loss of material I built the doors back up to size with plastic card.
    The hinges are again just plastic card from the scrap box and a simple wire hinge pin that I can pull out if I need to remove the doors.
    The actuator is a simple scissor action with a push pull that can connect to a servo or whatever.
ID:	99846Click image for larger version
    I used 14ba screws to hold the lot together but if you have fingers like bananas forget it! its a ***** to put together ---- you WILL need eyeglass and tweezers (no one said it would be easy) Editor's note 14BA = Fine English Thread
    I have included a couple of pics of my folding vanes too, again mostly made from scrap plastic card and a few plastic gears. I am sure that if there is enough interest David Merriman would do a kit of parts, if so you can have this one David with my compliments (as long as I get my chocolate tea pot)
ID:	99842Click image for larger version
    • 13954
    Excellent work, Ron. The way you made the scissor work to pull those doors open is pure genius. I'll steal that idea!
    However, I've had the bow plane retract mechanism skulled out years ago. It's now an element of our GATO Fittings Kit, which have been selling very well. The below shots are of the initial master work on that mechanism.
ID:	58332Click image for larger version
ID:	58333Click image for larger version
ID:	58334Click image for larger version
ID:	58335Click image for larger version
