SS-1 Holland
  • redlite
    • Jan 2010
    • 31
    SS-1 Holland
ID:	99723I've always wanted to RC my little 16in., all metal Holland and when I saw the 1.25" WTC, it looks like it might be possible now...I'm a bit worried that the metal hull might act like a 'Faraday Cage', perhaps run the receiver wire outside? Anyway, the model performs very well with just the clockwork motor and will dive and surface repeatedly or one long dive/surface or just 'surface run', depending on the dive plane setting. I used the drawing by Jim Christley that's on the cover of SCR, issue #16. The model incorporates some Chinese junk toys and a Marx windup mechanism, the rest is brass and solder, lots of solder....I have a couple on the work bench now that are half done, so I'd like to try and convert one to RC. Has a time limit been established for the contest yet?
    Joe
    • 13921
    Mike and are are kicking around the close-out date. Later in the year, Novemberish I think.
    Wow, what an innovative and unique application of wind-up technology. Yeah, the r/c signal won't punch through all that metal, use the existing jumper wire off the mast as your external antenna and you're off to the races. A very, very unique application of 'junk'.
    • redlite
      • Jan 2010
      • 31
      Thanks, David. OK, that's good, late fall will be plenty of time, so no excuses now. A note of interest, the model uses one of the things that the ADF eliminates, i.e., resistance, hence the open hatch and masts, which causes the sub to surface. I have a current build thread on RCG-submarines at the moment, showing the build process and even some old tin subs from around the world. Give me a couple of weeks and I'll place my order for the WTC and some equipment.
      Joe
      • redlite
        • Jan 2010
        • 31
        I received my 1.25" WTC from Caswell and it fits nicely inside the hull. I added brass control horns and clevises to the rudder and dive plane, then soldered the tail unit onto the lower hull.
        • redlite
          • Jan 2010
          • 31
          I soldered some brass channel for supports with rubber band hooks. A dual servo box seemed easier than trying to fit both servos in one box. A built in 3:1 reduction from motor to prop would be nice and the only thing I would change in the whole 1.25 in. system from Caswell. It is user friendly and versatile, worth the small investment. Next, a gray paint job and some flotation and she'll be ready for trials.
          • redlite
            • Jan 2010
            • 31
            The deck has two screws and one bolt to hold it onto the hull. It takes about two minutes to interchange with the windup hull.
