ssbn659 Victor
  • snow1992
    Banned
    • Aug 2013
    • 1
    Advertising deleted
    • SSBN659
      • 406
      In this post I show a photo using my laser level to check alignment of the rudder and stern planes. The laser level has been very helpful in this and other important alignment tasks such as establishing and maintaining a centerline on the hull as the work progresses. I’ve marked the centerline with a Sharpie and sometimes have driven in finishing nails along the line to maintain it. The nails can be removed and the holes filled as the project nears completion.
ID:	82915Click image for larger version
ID:	82916Click image for larger version
      Installing the linkages for the rudder and stern planes can drive you up the wall, especially on the Soviet boats with the long stern taper. One way around this at first seemed a bit drastic, but it worked. I cut out a hull section and made ready to install the linkage as shown in the photo below. Once the linkage was connected it was easy to epoxy the bottom hull piece in place.
ID:	82918Click image for larger version
      There’s more to come later.
      SSBN659
      • SSBN659
        • 406
        I’m jumping ahead here for a moment to show what the linkage looks like after several runs. I wouldn’t have been able to get it all in there if I hadn’t cut out the hull section.
        Although the boat ran fine for awhile, I found some seal leaks on the 3” WTC (now Sub-Driver) so I set it aside and haven’t worked on it for a few years.
        Now, on to painting. I experimented with blue tape to mask areas that would end up white after painting the hull black or dark grey.Click image for larger version
ID:	82968Click image for larger version
        It took a couple of times before I got what I wanted.
ID:	82971Click image for larger version
ID:	82972Click image for larger version
ID:	82973Click image for larger version
        Building this boat was a real challenge because it was my first attempt at a scratch build RC model. If I were to do this boat again, which I’m not, I would try to build the contra-rotating props that I’ve seen in several pictures of the Victor III. That would be an even bigger challenge. Right now I'm doing a major overhaul of the Alfa you see in the last photo. Perhaps more on that later this Fall.
        SSBN659
          • 12336
          What can I do to help you with that WTC?
          dmeriman@aol.com
          • SSBN659
            • 406
            David, Thanks very much for offer but I've already replaced the seals.
            I purchased the 3" WTC in 2005. Since then it has run my Permit and my Victor giving me several hours of enjoyment. I've even used the motor end in my own cylinder to drive my Alfa as a dynamic diver. You helped me several times over the years when I need a part or advice with never any questions asked and now 8 years later you are still there ready to help when needed.
            Folks, I know of no better customer service!
            Thanks again.
            SSBN659
              Hey Will, I looked again at your thread from the Model Competition where you constucted a Forty one for freedom boat. Nice job. Where I am going with this is that your Victor is partially in a picture from that thread. That post was started on 4-28-2010 so youve had the victor for a while. Thanks for sharing all this with us.Click image for larger version
              • SSBN659
                • 406
                You have sharp eyes, or good memory, or maybe both Mark. Yes, it's been along time. I looked back through some files and found I had started collecting pictures of the Victors back in 2004. It was 2006 when I started the model.
                SSBN659
                • Anuci
                  Banned
                  • 165
                  You are most likely a true modeler by the look of your work as presented, SSBN659. Scratch building is most definitely a skill not all are in the position to tackle, for one reason or another. One can certainly appreciate the skill level you have displayed here with your Victor class, taking it from nothing to the finished product as you have is most impressive. Your patience, and dedication to complete what you had started some time ago has certainly paid off. I had wondered if you have had the opportunity to sail the sub since completion, and curious of its performance, but non the less an excellent build. Good luck, in the Builders competition.
                  Al,
                  • SSBN659
                    • 406
                    Al, Thank you for your very kind comments. The Victor was my first attempt at fiberglass and although I made a lot of mistakes I knew could overcome them if I worked at it. I also wanted to share what I had learned from some really good modelers to show that even a novice like me could do it. And yes, I got a lot of runs out of Victor at our neighborhood pool. A funny thing happened at an early run. A young girl and her dad watching me run the boat at one point said "Why is it sitting on the bottom Mr. Rogers?" How do you answer a question like that? Unfortunately we moved when I retired and no longer have access to the swim club so Victor sits on a shelf in my shop.
                    Thanks again Al,
                    "Will" Rogers
                    SSBN659
                    • SSBN659
                      • 406
                      With all the discussion about post war Soviet subs including the Victor I went back into history and brought up this build. This was a one off build that I later sold as downsized my fleet. Sure would be nice to see a new thread on building a Victor III.
                      "Will Rogers"
                      SSBN659
                        • 12336
                        I remember this WIP! Great job. And a first-effort too. And where can Bart and me purchase a copy of that drawing you showed in your most recent post to this thread?
                        • SSBN659
                          • 406
                          Tried to send you a pm but your inbox must be too full. Please send me your mailing address.
                          "Will Rogers"
                            • 12336
                            "Will Rogers"
                            David D Merriman lll
                            835 Holly Hedge Ave.
                            Virginia Beach, VA 23452
                            • SSBN659
                              • 406
                              Thanks. I'll send you a tube of drawings in the next day or so.
                                • 12336
                                #30
                                Excellent, sir. Much appreciated. I'll make my copies, get things in phase with Bart and we're off to the races, and return your originals. Much appreciated, Will.
