Credit goes to the two other guys I mentioned. I can only credit myself only in trying to not 'F up' their prior good work. I may add a thin rubber custom cut gasket using the housing as a template and fill the gear box with a grease. The gasket to prevent oil building in the interior of the sub and coating the Dive module.
It runs fine; I can turn with my fingers the center shaft. Concerned about electrical draw on the battery, so also considering belt drive arrangement too. If you add some extra wheels on one side, the shafts will contra rotate. It may run smother and draw less power. Best is two motors, but again as I mentioned earlier, can't afford another $1100 on a alternate Dive module twin shaft, so accepting some inefficiencies.
Tom Anderson has been most helpful and generous. He charging me only cost of matericlas to print. $78.80. He offered to print Randy Sanders files. Randy kindly increased the scale for me to 1/48 for the RC boat and 1/96 for the future museum static model to donate to the Vallejo museum. No more worries about fighting a Chinese 3 df printer now an d burned out mother boards, no spare parts (criminal all to eliminate inventory. **** how much space does a mother board use? F*** the Chinese.
All building projects now printed past that logistical hurdle. It was a little like France ship building in the 1920's and 30s , no launching ways and dry docks except the Normandie dock in Saint-Nazaire (over 1100 feet long) to build really huge ships in. the fast battleship Richelieu, the hull had to be launched without a bow or stern and welded together after. No need now top send a ton of money infrastructure for the shop now.
Here is a possible idea for a alternative belt drive too. Using components for a new belt drive idea.
