More Production Photos from The Cave
  • Slats
    The tooling and first batch of resin and metal parts for the Type-9 fittings kit are in hand. Got a problem with the propellers though, they are distorting in the tool during rotation, so I have to redesign the process. Other than that I have stuff to sell but no supporting documentation -- need to find the time.
    For the first time in three years I've caught up with the purchase orders so I can now attend to that and other tasks ... the ALBACORE kit you mentioned is one of 'em.
    Sorry it took so long to get that stuff to you, I know you were looking forward to a regatta. How's that panning out, John?
    All good here David.
    Your Type 9 gear should be a seller - be interesting to do a head count at the Regatta here as to people who have bought them already and those who are wanting to buy them.
    I'll be taking the USS Plunger with me to the Regatta. I'm going to have the new 3.5" SD that I bought set up so that a separate channel pinches off the snorkel head line due to the very limited space in the Permit Class sail.
    I'll be also taking the new torpedoes down to the Regatta and doing some test firing of these versus the older type. I'll hand fire the tubes (not from a sub). The torpedo tubes I'm planning on installing in the Astute. On the subject of torpedoes - a consumable that I need to buy if its available are some springs that push the breach out of the way. Firstly these do wear out, and second I have found that for servo activation often its better if the spring is under a bit more tension via putting a small piece of plastic tubing around the shaft that the spring pushes against.
    I think I might mothball the plastic Albacore I have as the GRP boat you have in the pipeline is too tempting not to buy. Looks like there's ample room in the sail of that boat for a float head valve for the SAS.
    Had the Astute 72nd plans out on the weekend. That beast sits very high out of the water - could pale a Soviet boat for the ballast tank size it may need.
    Best J
  • crazygary
    Ahhh! A bit of the , "Bond! James Bond"!!
    Pussy Galore, indeed!
    Well done, Hermill!!
    Hey!! Didn't J.B. have a neat little one-man sub??? Hmmm!!
    Originally posted by Slats
    Apart from playing with Pussy, where are you up to with the Type 9 conversion kit, oh and that bloody GRP Albacore David?
    My parts David have just turned up (thanks again). I' don't mind paying customers clearance - helps my country function, but gwad almighty did they ever **** about with clearing the shipment - dealing with people over here that no doubt require assistance to chew their food.
    Best J
  • Slats
    Originally posted by herrmill
    Who says who's playing with pussy?
    [ATTACH=CONFIG]26297[/ATTACH]
    Not sure Ellie would want her to be fed his nuts
  • herrmill
  • Slats
    Best J
  • crazygary
    Had to have him fixed, eh??
    Got a broken one right outta the box, did ya??
    Bummer.dude!!!
    (hysterical chuckling)
    crazygary
    Ha! Just asked her what that means. Too late, we had him fixed as a kitten.
    You could ask Ellie to make him into a "siopao"
    Indeed! And Ellie just got a letter from the City saying we have to buy that worthless fuzz-ball a 'license'. His Majesty had better learn how to crap in the toilet or he's outa here! Damned thing has all the love-appeal of a land-mine.
  • herrmill
    That guy has CATTITUDE!!!
  • crazygary
    Sorry to hear about your nuts, M!!
    However, Mr. Cat sure looks content!!
    crazygary
    Your would-be apprentice likes your work & wanted to let you know that her offer to intern as your PA is still open.
    Ellie would feed the cat my nuts.
    Installed and tested about five-hundred dollars worth of MPC's this afternoon. That was preceded by a pressure test of the pumps -- if a pump is a leaker, I want to know it. Otherwise I wind up saddling a customer with a bum unit.
ID:	90175Click image for larger version
  • herrmill
