I came across this article on pressure vessel design which may be of general interest.
Direct link to the PDF;
While it specifically addresses the design and sealing of pressurised oxidiser / fuel tanks of small amateur rockets (ie. keeping high pressures inside), there is a good description of sealing methods, pressure ports types and analysis of potential failure modes which may be relevant for WTC design
