Que up your pictures so they can easily be accessed. I have them in a folder or on the desktop screen.
Type your Text here then to add a picture (very important-it will make your posting easier) hit the enter key once or twice to move the curser down. This will provide room for the picture with the text above it.
Now Drag the picture to below the line with the 13 dots...next to where it says "upload attachments" / "upload files"- that window will now say "Drop Files Here to Upload"
When you drop the pictures there, you will now see a thumbnail of your picture, the file name, and the words "small, medium, large, fullsize, and remove" Pick the size you want to post and click...
If you don't like it click "remove"
If you want subsequent pictures side by side Place the curser next to the picture make sure you don't make the pictures too big or they will run out of room and disappear to parts unknown.
If you want the pictures vertically displayed, use that enter key to move the curser below the existing picture.
Remember treat the picture like text -it needs the curser to give it placement, either next to or below what is already there.
Use Enter Key to place pic below text or click curser next to text to place it aside the text...then drag pic and drop it as seen above..
You will now see the thumbnail and choices for size or removal..
Click on the size and the pic will be placed...
The curser is placed lower right corner of existing picture If you want side by side placement of the next picture...
Use the enter key to place the curser under the existing picture if you want vertical placement of the next picture...
Drag and Drop the next picture -select size...and Bob's Your Uncle-BG
