More products
    More products
    The unit on the right has been removed from this sale. An ordinary end cap replaces it.
    2.5" diameter
    23" long
    4" ballast tank
    3 pushrod seals
    Snort tubes in Motor bulkhead
    Gas servo installed. No Gas saver system.
    Equipment tray
    12volt 380 motor gear reduced RPM
    It was used for a 1/16th KAIRU
    $140
    20" Pre-drilled 3.5" diameter Lexan Cylinder
    2 x 540 motors - Needs shaft extenders
    Equipment tray
    Motor Bulkhead with gear reduction and push-rod seals
    Ballast bulkhead with vent/blow equipment (vent valve included - not in photo)
    Forward end cap.
    Propel Gas Tank
    (Can also make up a battery cylinder)
    $150
      TThese are Graupner 400 7.2 volt motors with Graupner gearbox 4:1 reductions. Some have long shaft extensions, some don't.
      $$6 each
      Get em while they're - well -- you know!
      • SSBN659
        • 417
        Mike, Sent you a PM about the gearbox motors.
        "Will" Rogers
        SSBN659
