With a little work, you can make this unit into almost any type of WTC you like.
I've thrown in the little unit so you can rob it of the gas ballast bulkhead and vent system. Having it already assembled helps to see how to put it together.
The black disk is the battery compartment bulkhead cast in epoxy out of David's molds.
3 mini servos
1 400 motor and gearbox mounted in the motor bulkhead.
2 seals supplied
Propel gas tank
Forward end cap - needs tire valve. No it doesn't there's one in the small tank
Equipment tray. Needs a strap to hold it over the motor.
$145.00 a steal!
