The instructions on the SL-8 rx state "Turning off the DSP will help in locating the source of glitches in the model". First what is DSP and what is the procedure to locate the glitches, the instructions do not say. Thanks
DSP mode?
Tags: None
The DSP functionality of the SL-8 processes the analog baseband to eliminate any noise that may translate into jerky servo/throttle movement. Having this feature on can mask issues with RF/electrical interference. If you suspect issues with range, etc., turn the DSP off and see if you get any unintended servo movements. DSP is also turned off when two transmitters are linked together in training mode.
