SL-8 Receiver (Synthesized, 72/75MHz)
  • Teaker11
    • Dec 2011
    • 21
    Good day
    I am new the rc submarine and have purched a Engel MK VIIc and my recevier is to big for the specs and was wondering if any would know if An Airtronics RD8000 transmiter 72 MHz/ FM channel 61 would work with the SL-8 Here are some specs on the transmitter : Modulation PPM/FM /PPM/FR Reverse / PCM1 and PCM2 Power output is 600mWatts Pulse width 1.5 ms Nominal if you need more information let me know and I will try to find it also would I deed the programmer with the recevier?
    Thank you for your help
    Jim
    • 3732
    Teaker11, I had asked on my old Futaba and here is the answer "As long as the transmitter is set for FM-PPM, it should work." I will let the expert chime in if I am wrong.
    tom
    • sombra
      • 27
      As Tom mentioned. It should work fine.
