ADF - a suggestion for a future model
  • roedj
    • 564
    Kevin,
    I have installed one of your ADF's in a sub and it works just fine - no complaints about its functionality.
    However, when I first installed it, the rear dive planes moved the "wrong" way. I didn't have the room to switch the arm on the servo and it was a real PITA to turn the ADF around but I finally got it to work.
    Maybe for a future product you could provide a means to switch the sense of the ADF - it sure would've made my life a lot easier.
    Thanks for your time and excellent products,
    Dan
    P.S. I'm thinking of mounting an ADF transversely in a surface ship and use the output to control roll by shifting weights although I haven't worked out all the bugs yet (in my mind).
    Hey Dan I have successfully employed active stabilisers on targets using a simple sub leveller (not the ADF) a much earlier one. Try something like this via two servos one either side of the ship and opposite setups and hooking in a Y harness to both servos. The system I employed was totally autonomous - only need a 5 volt pwr supply to work. The stabiliser fins work like a planes aerilons. As for weights try the stabilisers first - they are by far the easiest engineering solution using sub leveler type technology.
    • roedj
      • 564
      John,
      Interesting. Are the stabilizers "scale" or oversize to work better?
      (Am I hijacking my own thread?):D
      Dan
        John,
        Dan
        Slightly overscale in 1/72
        In the main I don't bother with this feature any more - its far better to build a target that is rock steady stable. If you can get a hold of the April 2009 Edition of "Model Boats" magazine. My HMS Ardent is on the cover and featured inside - this shows how to build top weight that is ultralight and strong at the same time. Yes thread is hijacked - sorry Kevin - Dan happy to take more questions etc over in the Target area.
        • KevinMc
          • 305
          Hi Dan,
          Sorry for having taken a while to acknowledge this post, but thank you for the suggestion. I'll see what I can weasel in on the next one!
          KMc Designs
