Hi
I got a new Viper Sub 10 from Caswell. Hooked it up and everything works fine! I have a 2.5" SubDriver With ESC, ADF2, LiPo Guard, Snort, Sombra 8 receiver and a Tracker III.
All are connected properly(checked by an officer like Rig for Dive). Setup mode performed step by step.
All the systems work: Fairwater Planes, Rudder, Stern Planes, Snort and Ballast Vent/Blow, Speed(ahead & astern).
I performed the zero Bubble Calibration ( press and hold set button 1/2 second). It says that the green LED will flash quickly for 2 sec. What I get is Green Solid while the red flashes quickly. I have done setup and zero bubble at least 5 times. Am I missing something or is there a problem with my ADF2? After each calibration I then move the ADF2 at different angles but get no servo movement. I turned off the tx and got a full blow from the failsafe
