11.1 V Gato Subdriver hook up
  • vital.spark
    • May 2010
    • 307
    Im doing the assembly on the Revell Gato Subdriver and I would like to know if there is anytihing I need to know or do when using the 11.1 volt battery supply? Or, can I just do the same electrical hook up as we did on the 7.4 volt seawolf and type VIIC, just adding the additional channel and servo for the retract opperation?
    I and I'm sure others would like you and or Kevin to post a good quality wiring diagram for both the 6 channel installation and also the 7 channel like the Gato when an ADF, Lipo Guard and LPB are installed.
    Regards,
    Myron
