OD of BATWTC battery compartment?
  • roedj
    • 564
    What is the OD of the separate battery WTC, P/N BATWTC and what is its length?
    Dan
    • 14006
    Sorry about the delay ... I was dealing with that PF **********.
    The OD of the cylinder is 3", it has a 1/8" wall thickness. Length is about 8".
    Last edited by Kazzer; 06-17-2011, 10:37 AM. Reason: Considering banning for bad language - its pink pantie time again!
    • roedj
      • 564
      Thanks for the info.
      And calm down, nothing on this forum is worth having to wear those lovely pink panties (although they do look good on you).
      Dan
        • 14006
        Ah, thanks ...
        ... I think.
        • roedj
          • 564
          Just to confirm what I think you said because I believed you had stopped producing anything with a 3" OD, if I buy a BATWTC I could plug one of your older 3" motor end caps into it with no problem. I have accumulated some of your older 3" product and have some ideas on how to use it using the tube and one end from a BATWTC.
          Please confirm that the tube from a BATWTC can be used with end caps and bulkheads from your older 3" WTC's.
          Thanks again,
          Dan
            • 14006
            E-mail me. I'll fix you up, Dan.
            • roedj
              • 564
              e-mail sent
              Dan
