HELLO,
I have a problem with my revell type 7. The surface and submerged trimming is perfect. It took me a week to get it spot on. However when I command a blow it tends to want to always lean to 1 side on surfacing. I have to hold it straight on surfacing and when the tank is empty I can let it go. If I surface it with the deck off, its ok. I drilled holes all over the deck so I doubt its an air bubble problem. I am using the D&E subdriver. Anyone come across this problem before?
Regards
Regards
