Revell Gato dive plane pin size
  • vital.spark
    • May 2010
    • 312
    David, what size brass pins do you suggest for use in the dive planes? These are the 2 pins one for retracting and one for tilting? I seem to get excess movement when using 1/16" pins.
    • 14013
    1/16" is right. if the bore has gotten sloppy on you, put a dab of CA in each end of the bore, catalyze, then bore out with a 1/16" bit ... presto-chango! You're back in business.
