leaking pushrod seal
  • vital.spark
    • May 2010
    • 312
    I have a leak in the bow plane pushrod seal on my VIIC Subdriver. I have a spare seal and would like to know the best way of removing the old seal and installing the new seal without causing any damage.
    Regards,
    Myron
    • 13984
    Remove the retaining screw from the servo bell-crank, pull the bell-crank off the servo. Disconnect the pushrod and pull that pushrod out of the seal. From the inside push the leaving seal body aft -- it's secured with RTV silicon adhesive, so it won't put up much of a fight. Install with RTV the replacement seal, let dry, then make up the pushrod and test.
    • vital.spark
      • May 2010
      • 312
      Thanks David, This is what I thought but it is better to be safe then sorry!
