Micro Snort pump specs - voltage question
  • Slats
    • 1776
    Mike and David,
    the sticker on the pumps says 6V - I have been running at 7.2v for sometime with no (known) problems. I note the spec below says * Rated Voltage DC3-7.2V on your pumps page. But wondering why the sticker says 6v.
    I take it 7.2v remains to be ok?
    John
    From the Caswell models page re pumps:
    MICRO AIR PUMP
    * Outlet Airflow 0.62l/min
    * Max Pressure 60KPa
    * Max Vacuum -10KPa
    * Maximum Current 0.45A
    * 43.3×21×12mm
    * Practical ‘in the field testing’ gets 17 psi and -12" vacuum. It will not re-start until the pressure drops to about 10 psi. Draws approx. 0.2 amps at it's maximum.
    sigpic
    • 12389
    OH, MY GOD!!!! Run!!! Save yourself!!!!! Way, way too much Voltage!!!!
    DANGER .... DANGER .... WILL ROBINSON ... D-A-N-G-E-R!!!!!!
    (please)
    • Slats
      • 1776
      Yeah David I get it 7.2v is fine- from God to the king of sarcasm you speak my language....but sarcasm aside - I am puzzled by the pumps sticker of 6v. Usually I find labels like that are the manufactures max voltage, or is this a case of manufacturers being overly cautious?
      J
      sigpic
        • 2848
        (please)
        Good Grief!!!!!! OVER ACTING!!!!!!
          • 12389
          J
          OK, I've had my fun.
          Seriously: I can't speak to what this particular Chinese firms criteria is as to voltage tolerance and how it's applied to their labeling. All I know is that I've run these pumps at a voltage as high as 11.1-volt (limited duty, of course) with no apparent ill effects. So, I'm comfortable running this pump-motor at 7.2-volts all day.
          (crackle of thunder) I HAVE SPOKEN, SO LET IT BE WRITTEN!
            So let it be written...........so let it be done!!! Hey Dave, Sir , could you please respond to the Up Periscope question on this D&E Technical support please. I am at a standstill until I can hear from you . Thanks
