need some info
    Originally posted by satlite440
    thanks for the call,david.was wondering if it had shipped yet?no sighn of it on this end..
    Got it off last Tuesday. Thanks for being patient with me.
  • satlite440
  • satlite440
    hope you feeling better.being sick sucks
    just getting over a terrible bout with the flu. This week. Sorry for the delay.
  • satlite440
    just finaly got back from a week lonk set of classes on hybrid and electric car transmission classes out of state and thought I would check in.and see if there is an update?
  • satlite440
    mostly wanted to make sure you got it.thanks
    well did I totally mess u the engine room?
    I doubt it. I have not even opened up the box -- got snowed under with Caswell work. I'll fix it tomorrow ... promise.
  • satlite440
    your the best....I will try try my best to keep drydock overhauls from bad captining to a dull roar in the future
    Don't agonize over this too much. Glad to help.
  • satlite440
    Excellent. If the seals are the only problem, I'll have that bad-boy turned around in one working day.
  • satlite440
    going out today at 3 via ups.tracking#1z 972 843 43 4625 9477........thanks again
  • satlite440
    ok will do
    Let me fix it. ​David Merriman, 835 Holly Hedge Ave, Virginia Beach, VA 23452. Just send me the motor bulkhead with attached equipment tray, nothing else. Oh .... and a note telling me what needs fixing.
  • satlite440
    started a topic need some info
    need some info
    so after a lon gset of issues.i now have a wfly wft09 so I can set end points(after I read how too) I seem to have burnt up the shaft seal for the props as I have an leak in the engine room and after putting a hose on the valve stem on the outside of the rear bulkhead and blowing the moter shafts are the only place I get bubbles..so I need to know what seals to order. for spares.also is there some instrutions for changing out the shaft seals for the subdriver....I did get the lpb plumbed in finaly for trimming but the leak stopped that.. so nowthats where I am..or should I return it to the pens for the experts to repair??????
