Help
  • jigger
    • Jan 2011
    • 1
    Help
    I am interested to build an equipment which will help for fishermen to put gillnets under ice. Today they have to drill many many holes after each ten meters and it takes a lot of time. So, as you have knowledges of building submarine models I hope you can help me. Shortly we need an equipment which is able to pull an thin line (not the whole net) under ice. It should go at least 200m under ice and then we need to locate it through the ice where to drill next hole and get it out. It should be quite cheap, simple and durable. We would like start with production of it. My mail is info(at)egtt.ee!
    • 14013
    Cheap?
    right ....
    Try this outfit: http://www.roguesubworks.com/ Ask about their adaptable WTC's. Might be just what you're looking for!
