Italeri's PT-109 to an RC model....
    The DVD, Devil Boat: The Saga of PT 658 is the one I was speaking of earlier. I watched it again yesterday just so I could answer the questions that were brought up. It is a Higgins boat The famous exhaust Mufflers that you see on the back of PT109 and others are not there. Instead they have curved exhaust stubs coming out at the water line on the sides. A great DVD. It has a lot of video from actual WW2 films and the real life drama of the restoration. Youll be glad you got it.Click image for larger version
ID:	81961Click image for larger version
      Amazon has it, note the Link. I have the book shown beneath it as well. Outstanding.
ID:	81975Click image for larger version
ID:	81976Click image for larger version
ID:	81977Click image for larger version
ID:	81978Click image for larger version
ID:	81979Click image for larger version
ID:	81980Click image for larger version
        • GBerger
          • Oct 2010
          • 18
          I think they all turn to the right.....GClick image for larger version
          The Titanic" The smoker you drink, the player you get"
          • GBerger
            • Oct 2010
            • 18
            He Who Shall Not Be Named has requested some shots of my 1/16 PT project. Well? for He Who Shall Not Be Denied are a few pictures of the progress. Originally started in 1982.....yea that's right, it hung on the ceiling in the garage for its turn on the bench. Many projects and years later it's getting its turn on the bench. Click image for larger version
ID:	81986Click image for larger version
ID:	81987Click image for larger version
ID:	81988Click image for larger version
ID:	81989Click image for larger version
ID:	81991Click image for larger version
ID:	81985Click image for larger version
ID:	81992Click image for larger version
ID:	81990Click image for larger version
ID:	81993Click image for larger version
ID:	81994Click image for larger version
ID:	81995Click image for larger version
ID:	81997Click image for larger version
ID:	81998Click image for larger version
ID:	81999Click image for larger version
ID:	81983Click image for larger version
ID:	81996Click image for larger version
              • 14011
              Do you want it fast? Or, do you want it good? Pick one!
              Thanks, Gene. You've taken us all back to school.
              • vital.spark
                • May 2010
                • 312
                I mentioned the 85' ASR boats I worked on while in high scool in D.C.. Here is a site that gives specs. info, drawings and some pictures. The lines are beautiful, sheer, bow overhangs, curved transom etc.. Have a look!
                http://www.warboats.org/crashboat.htm
                • alad61
                  • Jan 2012
                  • 476
                  Nice shots Mark am I right in saying the boat you posted is a higgens 7o foot series?
                  Thanks as well Gene. That is a damn fine model your doing.
                  David getting a working conversion that is as true to scale as I can do is my primary goal at this point. Most conversion I've seen on the net so far that run the 3 props have them all going in one direction. They seem to get around the prop walk by having slightly larger rudders behind each prop. Scale props would be pretty much 20mm all with a RH rotation. The pro-boat rtr version runs only two that counter rotate. But as I said above I want to try to stay close to scale. So far at this point I'll have to concede with the rudder size as the true scale ones would be a little inadequate to make it easier to run the boat.
                  Cheers,
                  Alec.
                  Reality is but a dream...
                  But to dream is a reality
                    Yes thats right , its a Higgins, denoted for one thing by the distinctive exhausts.
                      One thing(of many) that I learned from the DVD is that the Elco PT boats were a British design that was copied and then later modified endlessly including lengthening the hull and strengthening some design flaws.
                        I think Ill pull out my PT boat book and post some pictures. Any Requests???
                        • alad61
                          • Jan 2012
                          • 476
                          Gene if I can mine to look half as good I'd be a happy little vegemite indeed!!!
                          Cheers,
                          Alec.
                          • alad61
                            • Jan 2012
                            • 476
                            Trying to find a good colour picture of them is interesting. As these boats did a fair bit of night stuff there aren't a lot I have found yet. I know that the 109 and many others that worked that theatre were painted green over the initial navy Grey's from the dock yard. They did that as a way to blend into the night and the back drop of the islands shorelines. What I have found so far is no definitive agreement on what green and that they were painted with anything from a brush to a mop. So I guess I'll have a bit of creative license when it's time to paint it.
                            Cheers,
                            Alec.
                              There is a few color ones in this batch.
ID:	82017Click image for larger version
ID:	82018Click image for larger version
ID:	82019Click image for larger version
ID:	82020Click image for larger version
ID:	82021Click image for larger version
ID:	82022Click image for larger version
ID:	82023Click image for larger version
ID:	82024Click image for larger version
ID:	82025Click image for larger version
                                I looked thru my book and there is not a single color picture in it.
