Battleships and their motors
Depending on which way you want to proceed, most of the ARTR models from KY or TJ come with brushed 550 & 400 motors with a 30A cheap ESC.
Your Trumpeter conversions certainly won't need those, especially if you plan to run all screws like with Arizona - something like a 250 would suffice which is what I used in the Sov I built, but then you'll find some like CMPANG going brushless.
Will you be adding Trumpy's new 1:200 Bismarck to your offering?Leave a comment:
well im not shure but my target boat is 3 ft long and weighs about 9 pounds with both batts single drive shaft and i use a dumas 6vt moter and for a displacement hull goes very fast with a 40mm 4 blade prop. waiting to see how it does with the 60mm 3 blade brass one im waiting for..so 2 moter with short 12inch shafts should cruze pretty good.. as a side note on the next surface driver i make with my other dumas 6vt moters i will wind a water cooler pipe with propwash pickups to provide some extra cooling as it gets warm after 35-40 minits of consatant run time. won't burn your fingers but is warm..Leave a comment:
We have several models which are in kit form. I don't have all the kits posted yet, but the RTR models are on our new site.
Could anyone tell me what size motors and how many are needed for each ship?
See the models here
Tags: None
