Hello all
I am new to this Forum and this is my first post and my first submarine
build.
Can some one help shed some light, I am looking into converting Revell's 1:72
type VII U- boat. I have seen the Sub Drive uses a Ø2"(50.8mm)OD tube with
1/8" (3.2mm) wall thickness. and also uses 2 × 280 size motors.
The problem that I see is that the internal diameter of the tube is 44.4mm
and the diameter of the 280 size motors that I have found are 24.5mm. So
24.5×2= 49mm width will not fit into the Ø44.4 tube.
Am I missing something or are the 280 motors (mabuchi RC-280SA) that I have found have a larger diameter that the ones used in the Sub Driver. or is the 2" referring to the
internal diameter and not the external.
I hope this all makes sense.
build.
