Dragon Shark 1/72 Sub
  • Tugrat
    • Jun 2010
    • 26
    I am considering purchasing a Dragon Shark ARTR
    1) ESC
    Recommended ESC is a 12v 50a
    2) Reversing switch
    Recommended is a 12v 50a
    3) Servos
    I have several options
    Futaba3003
    TowerproSG-5010
    FutabaS9252
    I am tempted to go for the Futaba - proven std servo
    4) Pitch Control
    Recommended is
    APC-4 or LR2
    5) Depth Control
    ADC-1
    5) Combined Pitch/Depth Control
    LTR 5.3
    6) Fail safe
    FS-1
    Now for the questions
    I would like to try and use a Mtronkics ESC - a 10a version should be sufficent
    Rather then have a separate pitch/depth control I would consider the combined unit
    I have some unsued Mtronkics fail safes
    Should i have the fail safe activating the reverse switch to "blow" or can I use the depth control -fail safe to blow ( if the depth control has a fail safe and I choose the Mtronkics do i need to disengage this feature)
    This is to be my first sub purchase and is to be a learning curve. I am intending to take part in AUS sub regattas, possibly some TF72. I am also proposing to organise some regular sub runs in a public pool.
    who are you and which part of Australia are you from?
    • Tugrat
      • Jun 2010
      • 26
      Geoff in Sydney
      I sail targets with STGMBC
        • 2643
        I would go with a larger esc 15-20A, and make sure those are continuous ratings. I believe Mtroniks rate their controllers for continuous currents, but some companies can be economic with the truth to say the least.
        A leveller is quite adequate, a combined pitch and depth control is a bit OTT for this model, and I don't think you'll miss the depth controlling feature.
        Can't comment on the failsafe, but you definitely want something, or just use a receiver with built in failsafes. Dual conversion receivers have been found to work better than single conversion in chlorinated swimming pools.
          Geoff Welcome,
          I'd add to Andy's comment - if you use a Mtroniks ESC - don't use the BEC. Run a separate BEC.
          Have had mixed successes with Mtroniks ESC with the BEC working fine in one boat and playing up in another. All problems fixed however, by not using the onboard BEC.
          Have PM'd you more details.
            • 2643
            I would say the linear voltage regulators on the BEC's fitted to Mtroniks esc's will provide sufficient power for your model, give it a try.
            Most servos draw about 1 watt of power. The BEC's on Mtroniks ESC's should comfortably give you about 5 watts of power, so providing your servos are not binding up or stalling out, you should be fine.
            It's when you start hanging half a dozen servos off of the receiver buss that things start to get interesting.
            Andy
