Really Dumb question.
  • pjdog
    • 302
    There's no way the ballast dump servo plug will reach the radio receiver on the big Gato S/D with out a servo extension. So I'll assume I need one of those. What's the secret to get a hold of the servo plug and install the extension into the servo plug? I'm going to assume that I need some really long forceps. One with a little curve and one straight? Right, Help!
    Jack
    • 13973
    Jack
    What a dumb-ass question!!!! ...
    ... long pair of hemostats (get 'em from Harbor Freight). Or needle-nose pliers.
    • pjdog
      • 302
      Yep, you where right. Harbor Freight does have them. I ordered four, two 12'' straight and two 10.5" curved. Now on july 13th I can hook up the ballast dump thingy.
      Jack
      • toppack
        • Nov 2008
        • 1124
        I solder an extention on to the servo cable, and let it coil up in the SD. Too difficult for me, to connect/disconnect it down in the tube, each time I remove it.
        Of course that will require removing the servo or complete bulkhead assembly from SD, to do that, but it's only a one-time botheration that way.
        Rick L.
          • 13973
          Jack
          ... and perform horrible, unnecessary surgeries on small, defenseless animals.
          Ballast dump thingy?! God, I love them technical terms.
