robbe speed control
  • scaleship
    • Aug 2010
    • 14
    robbe speed control
    Got a question regard the robbe rookie speeed control .I like this speed control but the only thing it failed me is the build in BEC which i have to pulled out the red wire and run extra 4.8 battery which take up more space in the WTC .is there anyway i can run a seperate BEC ?
    • 3772
    short answer YES.
    http://www.sub-driver.com/battery-el...r-circuit.html is a link to the BEC. Just tie it off your main power supply (you already have the power [red] line disconnected) and then connect to RX. If this is clear as mud, let me know. Be glad to clarify.
    • scaleship
      • Aug 2010
      • 14
      okay sound good bec is on order !!! .thx again for a great info .
