Additional Switch
  • jlday1256
    • Jun 2011
    • 78
    Additional Switch
    In the SD 2.0, there is an unmounted switch attached to the ESC with a waterproof cover. I have an exterior waterproof switch that I installed on the outside of the battery compartment. This switch in the engine room now seems redundant. Any reason why I can't remove the switch and just hot wire the leads together? Any common sense reason that I am missing where I might want to keep it. Not much room in there.:wink:
    Doodah
    If you ignore the problem long enough, it will go away. Even flooding stops eventually!
    • 13991
    Yeah, I do just that in the tight confines of the 2" SD's.
    • jlday1256
      • Jun 2011
      • 78
      Thanks! It seemed fairly straight forward, but my common sense has failed me before.
      Doodah
        • 13991
        Hey, better safe than sorry. Proceed!David,
