I have an Up Periscope video camera and goggles. I would like to install the camera in my Seaview. Are there any specific instructions for using it that way? I see a couple of issues that I will need to address. First, the coax cable for extending the antenna will have to be a lot longer. How long can it go? Second, there is that thick portion of the window frame right in the middle. Do you offset the camera to the side so it can see out? Third, has anyone done anything with a low voltage drop-out regulator for the camera so that it can run off the 7.4V main batteries? Are there any other issues with the Seaview that I haven't thought of?
Thanks for the help,
