Fixing gouges
  • mickelsen
    • 94
    Fixing gouges
    Hi all,
    I managed to put a couple of gouges in the side of my Seaview. I want to repair them. Is there a type of "bondo" or filler that I can use that will bond to the plastic, and that I can then sand down to a smooth finish? I've never tried to do this before, so any help that anyone can offer would be appreciated.
    Thanks,
    Mark
    Hope is a harsh mistress!
    Mark
    • 13982
    Evercoat's line of two-part polyester based automotive fillers. Caswell carries them.
    Get the Rage.
    • mickelsen
      • 94
      Should I get Rage or Rage Xtreme? (Although I notice that Rage Xtreme only comes in gallons...a bit more than I need for a couple of gouges.)
      Mark
      Mark
        • 13982
        Mark
        Duh!..........
        • mickelsen
          • 94
          Why is Rage better than Easy Sand?
          Mark
            It isn't better, it's different.
            Rage is a creamy paste which doesn't flow, Easy Sand flows a little, so you only use it in very thin cross section. It's for finer detail work. A lot of these 'fine scratch fillers' are really hard, so difficult to sand, that's why this is called Easy Sand.
              • 2641
              I prefer to use epoxy putty, like Milliput or equivalent for very small areas of fine detail. I find polyester fillers are great for general dings and dents, but lack strength for anything pointed or sharp edged.
