Setting up propulsor to cone on 1/72 VIRGINIA-class
  • sgtmac1
    • Nov 2014
    • 19
    Is there a rule of thumb setting up the space between the propulsor cone and the propulsor? There also seems to be straightening blades, attached to the cone, directly behind the propulsor on the actual subs but it is well hidden...
    • 13405
    Best rules of thumb for rotors and open propellers as applied to model submarines:
    1. Total developed blade area (not projected) between 60-75% of the disc, less the hub.
    2. Pitch = diameter
    3. helical twist to conform to a constant-pitch type propeller
      • 3658
      please would you explain to the knuckle dragging person I am in simple language what #1 means?
      oh heck might as well include #2 too!
      peace,
      tom
        • 13405
        peace,
        tom
        I use graph-paper to do this.
        1. You work out, in square inches, the area of the circle a propeller describes -- the diameter is blade-tip to blade-tip. Subtract the area of the hub.
        you draw the profile of one blade within that circle and determine its area. Multiply that number by the number of blades. You now have total blade area. work out the ratio (percentage of blade area to area of the circle). Alter the blade area to achieve a total blade area to be within 60-75% of the disc, less the hub.
ID:	137761Click image for larger version
ID:	137762Click image for larger version
        2. Pitch is a linear measurement. The axial distance a proper advances in on revolution through a non-slip medium. A constant pitch propeller is one where each radius point along the span of the blade assumes an angle that will produce the same pitch as all other radius points along the length of the blade. If the diameter of the propeller is 3.5", then the pitch should be 3.5". Pitch is not a measurement of angle, it is a measurement of propeller advance in one revolution.
          • 3658
          Thank you, I am seeing the spark of light!
