Futaba Module
  • Kim Sleep
    • Nov 2013
    • 329
    Futaba Module
    Anyone know what model number for a Gold-Faced, metal-bodied Frog? it has pins on the bottom of the module, rather than the new units in the top
  • cheapsub
    • 193
    That's hard to find, the new one FP-tp-FM should work.
    same pin out just upside down.
    that give me the reason for finish putting the transmitter back together, will test it and let you know.
    I tested some time ago the "GOLD " transmitter working with 433 MHz module with out any change.
    • Kim Sleep
      • Nov 2013
      • 329
      I never really thought about just putting it in upside down, but I would think that would reverse the pins, and noit work....but I have been so terribly wrong before,.and maybe Im wrong now
      • cheapsub
        • 193
        Don't put one in yet, let me try it out Frist.
        Should not be like the JR module need another 6V supply.
        now I know why the new "JR" 2.4GHz module don't go in to the old JR transmitter.
        • cheapsub
          • 193
          Put the battery back in the transmitter, smoke came out, the end!
          Sorry can't help.
