Glue??
  • Kim Sleep
    • Nov 2013
    • 329
    Glue??
    When gluing together two Large surfaces of Styrene, what is best to use to glue 2 pieces together. I love Soe Goo, because its tough, waterproof, and you can peel off ares that are over-glued. This stuff shrinks when its drying, and creates a ripple effect. 2 Part Epoxy creates heat, and therefore ripples.
    Ive just bought a bottle of
    Zap-A-Gap, that seems to be a cyclo-acrylic glue. Whatcha think??
    • 13948
    You want a weld/fusion, not a simple third-party bond. You will use a cohesive to melt and fuse the pieces together, not an adhesive. Weldon #16 is my favorite for big jobs, the brushable solvent is fine for smaller work.
    Fuse whenever possible, bond only if you have to.
    • 598602G
      • Jan 2017
      • 518
      Go to hardware store and buy you a can of acetone. Welds styrene together like nobodies biz.
      • Kim Sleep
        • Nov 2013
        • 329
        Great , thanks....wow, a tube of Testors, havnt seen that since I was making models as a kid. Its off to Amazon to see if I can find any of this, none of the Hobby shops have any of it
        • Kim Sleep
          • Nov 2013
          • 329
          Ife always just sort of ignored the ripples in large area bonding before, and sanded/filled them out...now that I cannot sand as much, this will be better
