Reversing switch?
    Reversing switch?
    I know subtech use to make a good reversing switch -does anyone now make something like this?
    • 2642
    They still do- http://www.subtech.uk.com/acatalog/S...ectronics.html
      • 2642
      Also this one (relay based)
        Seen these Andy but
        Which one can be used as a reversing switch?
          • 2642
          Well there is only one switcher on that page- the SES-3, fifth gadget down.
            Andy,
            I have got one of these SES-3s - had no idea it could be a reversing switch.
            for an electrical dumb ass like me how do I rig this up to reverse a simple pump motor - so its forward one way - reverse the other?
            I.e. only have the positive and neg wires from the motor - I just don't know how to reverse it through the switch? Got a diagram?
              • 2642
              Ahhh, no sorry. I thought you wanted to switch a couple of separate functions. I don't think the SES will work for you when running it through a motor. You need a controller set-up as an H-bridge for something like this.
              There are switchers on the market that do this, e.g.
              But they're cumbersome IMO.
              I would just use a small reversible ESC, that way you also have proportional speed control of your pump. It'll almost certainly be cheaper than a switcher too.
              What's it for, a submarine ballast system?
                Thought about ESC but this is a pump solenoid combo. The solenoid needs atleast 6v to operate properly. The ESC giving proportional control wont activate it properly....so it looks like a couple of Microswitches and a servo then?
                  • 2642
                  You just need to make sure the control is fully over. A solenoid will normally latch in well before full voltage rating anyway.
                  Just try it out with a spare ESC, I think you'll find it works just fine.
                  • Bill Harris
                    • Sep 2009
                    • 23
                    I'd get the Dimension Engineering Double Switch (double SPDT relays) and wire it as an H-bridge.
                    --Bill
                      • 2642
                      Another solution- you could use the esc, with a Y-lead from the RX and use this to control a servo with some microswitches, the latter just operating the solenoid. I take it the solenoid has to activate both ways?
                        I'll give it ago.
                          Andy re the ESC - can this be linked to a Fail safe too?
                          I'd rather ask than screw up some electronics trying.
                            • 2642
                            Yes of course you can.
                            Another switcher I completely forgot to mention is Norberts ballast tank switch. this is custom made for the job, with a built in failsafe and undervoltage monitor-
                            Plug and play.
                            • ShadowPeo
                              • Jan 2009
                              • 14
                              Mike has them, Under product code SUB ES2 on the Switches and Solenoids Page (http://caswellplating.com/models/bhm.html) costs US$39.00. I have one of these myself and it seems to work alright although I have not loaded it up yet
